NTCE
Feb 14, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
NTCE
Mar 09, 2021Guide
I still have connectivity issues with my router.
Since the firmware update of the last shown on the Original post.
Has anyone or Netgear Team knows the cost or how can this be solved.
Also Router doesn't shows to ONLINE on Netgear App even when you have Internet.
Mar 09, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- vajimMar 09, 2021Master
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Also Router doesn't shows to ONLINE on Netgear App even when you have Internet.Unbelievable
