NTCE
Feb 14, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
darsenaux
Mar 17, 2021Initiate
I am having the same issue. I hear yall say a firmware reversion may fix it but when are they going to resolve this issue by issuing a new firmware version?
- FURRYe38Mar 17, 2021Guru - Experienced User
Need to first determine if your having a FW issue or not.
Some users are getting problems fixed with a factory reset and setup from scratch.
Others are changing there NTP settings.
NG does not make it public when FW updates for forth comming.
You can give us some feed back on what you have tried and done already.
ALso what configuration is our Orbi working on?
ISP modem or ONT info would be helpful as well.
darsenaux wrote:I am having the same issue. I hear yall say a firmware reversion may fix it but when are they going to resolve this issue by issuing a new firmware version?
