NTCE
Feb 14, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
phillipspd01
Mar 19, 2021Aspirant
Have had an issue with showing connected but no internet. what I found was to enbale parental control and then disable it will fix the issue for awhile but it comes back. have thought about a reset to see if that will fix it.
Not sure why this is happening. but it started after the last firmware update. also my model is RBR40 which is not listed in the model recommend list? confusing.
