NTCE
Feb 14, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
Apr 11, 2021Guru - Experienced User
Be sure to factory reset the RBR and RBS and setup from scratch. Power OFF the ISP modem/ONT for 30 seconds then back ON as well during the reset.
Be sure both RBR and RBS are on same version of FW.
vajim
Apr 12, 2021Master
FURRYe38 wrote:Be sure to factory reset the RBR and RBS and setup from scratch. Power OFF the ISP modem/ONT for 30 seconds then back ON as well during the reset.
be sure to be sure
- dokjonesMay 24, 2021Aspirant
don't waste your time with resets etc. The .104 firmware version is buggy and the only fix that worked for me was to roll it back. I assume it must be working for some people or it should have been pulled/an update released. Maybe it only affects specif versions of the RBR40 but this caused me no end of trouble for a few days especially since it looked connected but nothing was working. My observation is that DNS resolution/DNS server hangs and stops working so you cannot reach any sites.
be sure to be sure
- FURRYe38May 24, 2021Guru - Experienced User
If the reset doesn't work as last resort, then by all means, revert back to what has worked for you.
Resets have worked for others and is a valid troubleshooting step.
Good luck.
dokjones wrote:don't waste your time with resets etc. The .104 firmware version is buggy and the only fix that worked for me was to roll it back. I assume it must be working for some people or it should have been pulled/an update released. Maybe it only affects specif versions of the RBR40 but this caused me no end of trouble for a few days especially since it looked connected but nothing was working. My observation is that DNS resolution/DNS server hangs and stops working so you cannot reach any sites.
