NTCE
Feb 14, 2021Guide
Firmware update V2.6.2.104 - Internet Freeze, No Internet, Buffering, OFFLINE Status on App
I am having issues since the New Router firmware update. Hardware Version RBR20 Firmware Version V2.6.2.104 GUI Language Version V1.0.0.375 Operation Mode ...
dokjones
May 24, 2021Aspirant
don't waste your time with resets etc. The .104 firmware version is buggy and the only fix that worked for me was to roll it back. I assume it must be working for some people or it should have been pulled/an update released. Maybe it only affects specif versions of the RBR40 but this caused me no end of trouble for a few days especially since it looked connected but nothing was working. My observation is that DNS resolution/DNS server hangs and stops working so you cannot reach any sites.
vajim wrote:
FURRYe38 wrote:Be sure to factory reset the RBR and RBS and setup from scratch. Power OFF the ISP modem/ONT for 30 seconds then back ON as well during the reset.
Be sure both RBR and RBS are on same version of FW.
be sure to be sure
May 24, 2021Guru - Experienced User
If the reset doesn't work as last resort, then by all means, revert back to what has worked for you.
Resets have worked for others and is a valid troubleshooting step.
Good luck.
dokjones wrote:don't waste your time with resets etc. The .104 firmware version is buggy and the only fix that worked for me was to roll it back. I assume it must be working for some people or it should have been pulled/an update released. Maybe it only affects specif versions of the RBR40 but this caused me no end of trouble for a few days especially since it looked connected but nothing was working. My observation is that DNS resolution/DNS server hangs and stops working so you cannot reach any sites.
