ekstam1105
Aug 29, 2019Aspirant
Firmware update
I bought new RBR50 router. Current Firmware version is 2.2.1.210. While setup, it is showing new firmware version 2.3.5.30. Can I upgrade the firmware?
- Aug 29, 2019
ekstam1105 wrote:I bought new RBR50 router. Current Firmware version is 2.2.1.210. While setup, it is showing new firmware version 2.3.5.30. Can I upgrade the firmware?
Yes. 2.3.5.30 has been out for several months. Some people report issues and are unhappy. Many of us updated immediatly and have been quite satisfied. If it happens that you upgrade the firmware and discover problems, it is possible to "go back".
I would do it before anything else.
CrimpOn
Aug 29, 2019Guru - Experienced User
