ekstam1105's avatar
ekstam1105
Firmware update
I bought new RBR50 router. Current Firmware version is 2.2.1.210. While setup, it is showing new firmware version 2.3.5.30. Can I upgrade the firmware?
  • CrimpOn's avatar
    Aug 29, 2019
    Yes.  2.3.5.30 has been out for several months.  Some people report issues and are unhappy.  Many of us updated immediatly and have been quite satisfied.  If it happens that you upgrade the firmware and discover problems, it is possible to "go back".
    I would do it before anything else.
