azeal's avatar
azeal
Follower
Sep 23, 2019
Firmware Update
Orbi RBR using Firmware  V2.3.1.60
Got email msg to upgrade
Using Orbi app on iPhone, get ERROR msg that there's a problem checking my firmware so can't proceed.
Using my iMac I manually downloaded files but suspect they are only PC files & can't open them.
Any recommendations?
Hate to pay for support for this issue but willing to do so if necessary.
Thanks
azeal@comcast.net
    • CrimpOn's avatar
      CrimpOn
      The download from Netgear is a ".zip" file, correct. On Windows, we have to "extract" the ".img" file before we can upload it to the Orbi.
      (Rant: What is it with Netgear and (1) these emails telliing people to upgrade, and (2) the "app" which doesn't work!)
      • ekhalil's avatar
        ekhalil
        Master
         the Orbi app ALWAYS can’t reach the upgrade server then this is an indication of bad routing in the network. Please check for double routers. You can easily check this using traceroute command:
        Please open a Command Prompt (Terminal) on your Mac attached to Orbi and type:
        > traceroute 8.8.8.8
        1. If you see two private IP addresses listed in the first two hops then you have double NAT, and this can be the reason for the app not able to reach upgrade server
        2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the cause of the issue,
  • Retired_Member's avatar
    Retired_Member
    What did the email actually say?
    You MUST upgrade?
  • FURRYe38's avatar
    All .zip, .img and .chk files are OS cross platform compatible.
    Use a web browser, like Safari or Firefox or Opera ON your Mac to connect with the RBR/RBS web pages to up date them using there web pages. Update the RBS first then RBR lastly.
    There are issues when using the Orbi app.
    Thanks
    azeal@comcast.net
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi azeal
    I have sent you a message. Please check your inbox.
    Blanca
    Community Team
