esb2b
Dec 27, 2020Guide
Firmware Updates
I got an email to update my firmware, currently I am running V2.5.2.4, so whan I go to the advanced tab to check for updates it tells me I am up to date with V2.5.2.4, but if I navigate to manual upd...
esb2b
Dec 27, 2020Guide
I saw a thread where it updat4ed overnight - I wpudlnt mind that if mine auto updated, but usually you log into netgear and go to the advanced tab and update there - the advanced tab doesnt even show the latest updates anymore - this isnt normal
vajim
Dec 27, 2020Master
esb2b wrote:I saw a thread where it updat4ed overnight - I wpudlnt mind that if mine auto updated, but usually you log into netgear and go to the advanced tab and update there - the advanced tab doesnt even show the latest updates anymore - this isnt normal
do you know why you want to update? Problems with your system?
