rajung
Mar 01, 2019Aspirant
firmware updgrade for RBK50
I noticed there is a newer firmware for the RBR50 and RBS50 2.3.0.32
Currently have 2.2.1.210 installed
Useing the Netgear Genie it says I am up to date, doing some searching I see Genie not su...
Mar 01, 2019Guru - Experienced User
To get the latest, you need v212 loaded on the RBR first, then manually apply v32. Update the RBS first, then the RBR:
Useing the Netgear Genie it says I am up to date, doing some searching I see Genie not supported anymore so I figured I need to use the Orbi App on phone, but it also shows that I am up to date.
Any thoughts? thanks
