GWild
Jan 15, 2022Guide
Firmware upgrade capped satellite bandwidth at 50Mbps
Checked for firmware update via Orbi web interface, showed everything current. Visited Netgear CBK40 download page, showed new firmware for the RBS20 (two newer versions). Both updates related to se...
Oct 31, 2022Guru - Experienced User
Those screen are taken from the RBS web page and the RBS debug page. All RBS and orbi systems have this info.
My system is circa 2017.
GWild
Oct 31, 2022Guide
Your pages are different than my pages ...
- FURRYe38Nov 01, 2022Guru - Experienced User
The first picture is taken from the CBRs Connected Clients page. The 2nd picture is from the RBS web page. The 3rd picture is from the CBRs debug page. All of these are standard across Orbi systems.
FYI, this issue has been re-submitted to NG for review.
In mean time, you'll need to factory reset and setup from scratch and walk thru the setup wizard and be sure to set the setup wizard re-add the RBS20 to the system, then complete the setup wizard to regain the speed seen behind the RBS20. Do not change the transmit power on the CBR40 or you'll see the problem again.
