ninegag
Oct 09, 2017Aspirant
Firmware upgrade or not?
I am wondering if I should upgrade my firmware manually. The current firmware shown is V1.4.0.18. The introduction says that the system would upgrade its firmware automatically. But it seems that th...
- Oct 09, 2017
Ursa99 wrote:I too purchased mine from Costco and it had the same firmware. It worked just fine out of the box. I upgraded manually to the .72 and then the .74 firmware and it is still working just fine. Speeds are good and no disconnects. I have not had any of the myrid of issues I read about here. Mine setup has been running in both router mode and then access point mode with no issues. ...
Same experience here - It's been running well for me through the upgrades.
I figured the 1.4 firmware may be too old now to do the auto update. There may be security holes that you expose your network to if you leave it on the old firmware. Being in IT, I've seen what can happen so I would say upgrade for that reason.
ninegag
Thanks for both of you folks' quick reply.
I just upgraded my BRK53 system all to the latest 2.0.0.74 firmware version.
I had to upgrade each satalite seperately even if I checked both of them before upgrading.
The whole progress took me about 10 minutes.
I'll see if it works as perfect as the old version.
JustMakeItWork
Oct 12, 2017Apprentice
Read the other posts about .74 if you experience issues.
