eddie2046
Jan 16, 2022Follower
Firmware upgrade V2.7.3.22 causes RBS-50 To Continually restart – V2.3.5.30 Works Great
Firmware upgrade V2.7.3.22 was automatically loaded to my RBR-50 and two RBS-50 satellites. One satellite works and the second causes RBS-50 To Continually restart. The failing satellite only stays u...
- Jan 16, 2022
eddie2046 wrote:
Is there a patch planned or do I have to downgrade the network and disable firmware updates?
In over four years, I have never seen Netgear announce when new firmware would become available. One day, "there it is." It could be tomorrow.... next summer.... or???
If a Factory Reset on the satellite does not fix the problem, it seems you have no choice but to block updates and load firmware that does work.
p.s. I sent you a private message.
CrimpOn
Jan 16, 2022Guru - Experienced User
