bowmah
Jun 20, 2017Guide
FIRMWARE V1.11.0.20 (Did it help?)
Noticed there was a new update once I logged into the router so went ahead and updated the router and satellite. I am hoping this will eliminate much of the intermitent drops. I have not been able to...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
1speedman
Jun 20, 2017Tutor
Notice the update when logged on at 6:30 pm Pacific time. Too soon to tell, although my setup running 25 devices on the last FW was running pretty smoothly. Only time I had a issue is when I ran a speed check from my phone and my router shut down, had to reset my modem all the time to get back on line. Going to see if it will happen with the new FW update.
