bowmah
Jun 20, 2017Guide
FIRMWARE V1.11.0.20 (Did it help?)
Noticed there was a new update once I logged into the router so went ahead and updated the router and satellite. I am hoping this will eliminate much of the intermitent drops. I have not been able to...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
1speedman
Jun 20, 2017Tutor
Thanks.
Could you tell me when the USB port will be activated?
- marshymallowJun 20, 2017Apprentice
In the latest Beta FW, the USB port is actually opened for Printer Network Share function.
So looks like this may be at minimum be the first USB function to be released soon.
- peteytestingJun 21, 2017Hero
try putting a usb dongle ( with somefiles on it ) in the orbi router and open a windows explorer window and type \\192.168.1.1 ( or what even default gateway you are using ) and see what happens , you may be pleasently surprised
