bowmah
Jun 21, 2017Guide
FIRMWARE V1.11.0.20 (Did it help?)
Noticed there was a new update once I logged into the router so went ahead and updated the router and satellite. I am hoping this will eliminate much of the intermitent drops. I have not been able to...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
JMU1998
Jun 21, 2017Luminary
Another useless release with no substance, all major issues outstanding for Months and initial release still been headscratched!
samsamsamsam
Jun 21, 2017Guide
It made all the difference in my setup. I now have consistent connections with my iDevices when connected to the satellite.
- peteytestingJun 21, 2017Hero
