bowmah
Jun 20, 2017Guide
FIRMWARE V1.11.0.20 (Did it help?)
Noticed there was a new update once I logged into the router so went ahead and updated the router and satellite. I am hoping this will eliminate much of the intermitent drops. I have not been able to...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
bowmah
Jul 04, 2017Guide
When it drops, how long does it take to connect again?
And do you see the Wifi logo disappear or does it show full strength? If so, it may be the backhaul dropping and not your connection to the satellite.
mausser
Jul 05, 2017Initiate
I don't exactly know i always switch to flight mode to get back online, not bad voor a 420 euro router...
So turning back to AP setting will solve al my problems?
- DarrenMJul 11, 2017Sr. NETGEAR Moderator
Hello Everyone
Thanks
DarrenM
