Docmarky
Jul 15, 2017Follower
Firmware V1.12.0.18 bricked my RBK30 unit
I saw the firmware update this morning. The RBK30 system has been running flawlessly since I bought it 2 weeks ago. Clicked the Upgrade button. The system has never returned to life. No network. ...
Gwilcox23
Jul 17, 2017Initiate
Bricked. Unit led stays solid white...in the middle of streaming video and the router disconnects and nothing...should I thank you for trashing my unit? Shall I pay you to troubleshoot with me for hours to no resolve? Fix your pos you bastards! Not cool. Worked great for months. Going to leave bad reviews everywhere. Blah...glad ios issues got resolved, what about us people who never had ios in the first place?
jawilli312
Jul 17, 2017Aspirant
I received this email response on my (our) issue. I have not tried it because I replaced my unit prior. Posting here because IMO the reset procedures are counter intuitive (if not convoluted), meaning they may not actually be "bricked". Hope this helps.
For now, let's try to reset the router. Here are the steps to reset the router.
Note: The router should be powered on while doing the reset.
a. Please push the reset button (using a small pin or paper clip) at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
**This will make all the settings of the router back to default.
If the router will continue to show pulsing white for the ring LED, please do a shock reset. To perform shock reset, push and hold the reset button for one and a half minute. For the first 30 seconds, please leave it on. For the next 30, you have to unplug it. For the last 30, please plug it back in.
If the issue still persist, please disconnect the Orbi from your modem. Once done, we will ping the Orbi using your computer. Please follow the steps below:
- Connect the laptop via Ethernet cable to the Orbi router's LAN port and turn off the WiFi.
- Open Network and Sharing Center.
- Go to change adapter settings.
- Right-click local area connection or Ethernet and click properties.
- Highlight IPv4 and click Properties button.
- Select Use the following IP address and enter the following information.
* IP address: 192.168.1.100
* Subnet Mask: 255.255.255.0
* Default Gateway: 192.168.1.1
- Click Ok.
- Open command prompt in your computer and type the word "ping 192.168.1.1" without the quotation marks.
- taschmidtJul 17, 2017Tutor
Thanks for posting this. I had this issue and was unable to get the reset procedures to work. Speaking with their "tech support" was no help (they barely knew what I was talking about when mentioning things like hard reset, TFTP, etc). But I have a replacement due tomorrow and I'm a little nervous that the same firmware update is going to brick this new one.
