rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Butch1326
Jul 16, 2017Star
To stop the Orbi from installing the updated firmware automatically follow the steps below.
Perform these step after you downgraded the firmware to a prior release.
1) Launch your favorite web browser and go to <Router IP Address>/debug.htm
2) Login <username> <password> when prompted
3) Check Enable Telnet
4) Start a Telnet session. I use Putty. Enter the <Router IP Address> Telnet is using port 23
5) You can skip this step if you like. I am calling it out for illustration purposes only...
Type nvram show | grep auto_* <ENTER>
You will see a list similar to this:
root@RBR50:/# nvram show | grep auto_
vpn_access_mode=auto
wl_auto_antenna=1
set_auto_agreement=0
orbi_auto_upgrade=1
ipv6_autoConfig_dns_assign=0
ipv6_autoConfig_dns1=
ipv6_autoConfig_dns2=
upnp_enable_autoScan=0
ipv6_auto_dns_assign=0
bas_auto_conn_flag=0
orbi_auto_upg=0
autofw_port0=
ipv6_auto_dns1=
ipv6_auto_dns2=
qos_auto_bandwidth=0
green_enable_autorefresh_status=0
enable_dev_auto_refresh=1
wl_rate=auto
auto_check_for_upgrade=1
auto_update=1
root@RBR50:/# root@RBR50:/#
The 3 configurations highlighted above you will want to update the value from =1 to =0
orbi_auto_upgrade=1
auto_update=1
6) To update run the following commands:
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
7) Type the following commands to confirm the 3 configurations are set to =0
nvram show | grep orbi_auto_upgrade <ENTER>
nvram show | grep auto_check_for_upgrade <ENTER>
nvram show | grep auto_update <ENTER>
8) After you confirmed the 3 configuration values are set to =0 then type nvram commit <ENTER> (this step will save the changes)
9) Type exit to terminate the telnet session
10) Go back to the <Router IP Address>/debug.htm web page and uncheck Enable Telnet
Please note within a day or so the Orbi will know there is an updated firmware release available but it will not automatically install it. If you do go back into a Telnet session after the Orbi knows there is an updated firmware release the configuration orbi_auto_upgrade will have a value greater than 1. That is okay. Do not change the value back to =0
Tigerman4LSU
Jul 30, 2017Star
I did this and my router and satellite still updated v1.12.0.18. NetGear support is not helpful. I want a stable system.
- RogerSCJul 30, 2017Virtuoso
Tigerman4LSU wrote:I did this and my router and satellite still updated v1.12.0.18. NetGear support is not helpful. I want a stable system.
Did what? If you used the "config" commands that I posted above, my experience has been that my Orbi stays on whatever firmware version I flash. Very surprised if that's the case, hasn't happened to me. If you used the "nvram" commands, then yes, your Orbi will auto-flash the latest.
Did have a problem when I re-installed my desktop computer. Forgot to turn off power management on my network interfaces, and had problems until I remembered to do that. While that wasn't related to the Orbi, it had me thinking that the Orbi was causing disconnects until I took care of business. Now everything is nice and stable again.
Thanks.
