rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
dazzywazzy
Aug 20, 2017Star
Did you copy the NVRAM settings I posted, or someone elses?
cohoman
Aug 20, 2017Star
dazzywazzy wrote:Did you copy the NVRAM settings I posted, or someone elses?
Your's, I believe. I set the nvram settings for the router and the satellites.
- dazzywazzyAug 20, 2017Star
Using the below, I've not had the router or satellite update for 8 days now
FWIW my NVRAM settings which I changed are below
Router:
orbi_auto_upgrade=0
orbi_auto_upg=0
auto_update=0
auto_check_for_upgrade=0
auto_upgrade_flag=0
fwupgrade_Method=MANUAL
Satellite:
auto_upgrade_flag=0
Settings I'm monitoring but haven't changed as I don't know the outcome
Router:
detect_update=899798033
manual_upgrade=109908109666630
green_download_upgrade_stat=0
upgrade_satellite_image=109908109666630Satellite:
upg_status=1
upgrade_check=49902240
- cohomanAug 20, 2017Star
Router:
orbi_auto_upgrade=0
orbi_auto_upg=0
auto_update=0
auto_upgrade_flag=0
Satellite:
auto_upgrade_flag=0
Router:
upg_status=1
Yup, that's what I used. I modified those 3 specific settings on the satellite and did the "nvram commit" when I was done. For some reason, the satellite firmware upgraded to the newest version after I rebooted the satellite devices.
Could try changing upg_status=1 to upg_status=0 on the Satellite....If you feel like spending more time of course.
