rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
RogerSC
Aug 21, 2017Virtuoso
bsemerick wrote:holy whoa. 90 devices? Are you running a business?
That also struck me, expecting a lot of a consumer-level router. At some point, resource exhaustion becomes an issue...
madbrain
Aug 21, 2017Luminary
I have 38 static IP DHCP reservations in my router (R7000) at home. Not running a business, just have a lot of devices. 3 printers, 2 home theater PCs, 2 desktop PCs, 3 laptops, a solar meter, 1 chromecast, 1 Fire TV stick, Dish hopper, ooma huv VOIP, Rainforest eagle smartmeter gateway, one tablet, three smartphones, two electric car chargers, one networked AV receiver, one Kindle fire, two single board computers (Raspberry Pi and Odroid X4), one Smart TV, one cell phone booster.
Many of these, like printers and laptops, have the option of either wireless or wired, and I have set reservations for both. But I have been progressively switching everything I could to wired as much as possible, using AV2 powerline ethernet while my Orbi has been out of commission. Have found that to be much more reliable than Wifi.
The devices that are still Wifi-only don't really have a critical need for speed except for one HTPC located very far from my router to do network backups. The backups are way too slow over powerline. They really require Wifi AC speed.
