rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Tigerman4LSU
Sep 23, 2017Star
Good luck everyone with your Orbi System. I am returning my tomorrow to CostCo. I put a Ubiquinti System, business system, and it works great.
George
cohoman
Sep 23, 2017Star
Tigerman4LSU wrote:Good luck everyone with your Orbi System. I am returning my tomorrow to CostCo. I put a Ubiquinti System, business system, and it works great.
George
I also returned my Orbi system to Costco for a refund (thankful for their great return policy). I was just tired of all the dropped internet connections, slow speeds, etc. I decided to go back to a single traditional router system, so I bought the Netgear Nighthawk AC3000 R7900P WiFi Router from Costco. I was a bit hesitate to buying another Netgear router, but I thought I'd take the chance since I could return it so easily for a full refund. This new router has been running for over a week now, and it seems to be working well. It's a tri-band system with a 2.4 GHz and two 5 GHz transmitters. I've noticed that my newer devices (e.g., my LG G6 Smartphone) can send and receive at the highest internet speeds (125 Mbps down, 12 Mbps up) anywhere in my house on the 5 GHz system (even at a few previous dead spots). The 2.4 GHz is downloading around half the max speed in my home because I have the 20/MHz Co-Existance feature turned on (to help with outside overlapping WiFi signals). But that's fine since I'm maintaining a consistent connection to the internet. So far, this single router is working out ok for my home (knock on wood)!
