DarrenM
Dec 22, 2017Sr. NETGEAR Moderator
Firmware V2.1.1.16 auto update
we'll be removing the v2.1.1.16 firmware from the auto update server over the holidays and will resume pushing it in the new year. Firmware will still be available on product support pages for manual...
DarrenM
yes the reboot and disconnect issues are all being investigated.
DarrenM
aaz
Dec 22, 2017Virtuoso
DarrenM wrote:yes the reboot and disconnect issues are all being investigated.
DarrenM
Might I suggest you strongly look at the UPNP handling subsystem, I and at least one other person found that to be the cause. Both of us have seen UPNP activity when the reboots would occur.
I have every setting on except Circle and everything else is stable. I use the Netgear OpenDNS for content protection. I run it as a router not an AP. In fact I would recommend everyone just try to repeat my settings because this has been the most stable router I've had since my old netgear N600 a long time ago, which was way more stable than my Linksys WRT54G, Apple airport extreme, Dlink AC1200, Asus AC87U, etc...
