Rustyy
Apr 05, 2019Tutor
Firmware V2.3.1.44 Issues. RBK50 AC3000 with RBS40 Satellite
Hi team.
It seems alot of people are having issues with the recent firmware update. I only worked out I was having issues due to the Satellite placement in my house at the other end of the hou...
Apr 06, 2019Guru - Experienced User
I would manually update the RBS, You can connect a wired PC to the RBS and wait for the PC to get a temp IP address. After this you should be able to log in to 192.168.1.250 and get into the UI. Manually load the FW file. After it's loaded, I would do a factory reset and re-add it. Need to give it about 5 minutes to let it sync and settle in.
4+ days of uptime on a RBK50: However RBS is a RBS50 here.
| System Uptime | 04:18:02:32 |
