Sweetmo
Mar 21, 2020Tutor
Firmware V2.3.5.32
Today (3/21/20), I had an issue with my Orbi RBR40 connecting to internet, so I immediately went to the app and saw a note indicating new firmware was available. After two attempts to leverage the ...
Mar 21, 2020Guru - Experienced User
All FW files for the 40 series system are here:
https://www.netgear.com/support/product/RBK40.aspx#download
v32 may not have been put up on the download site as of yet. v34 is a security fix base on v32 so v34 will have what v32 had already. NG put v34 for users to manually download if they wish to.
If you want up update FW you can manually download and unpack the .zip files and manually install FW your self. RBS first, then RBR. Using a wired PC and web browser for this.
If your system is working you can also leave it. Thats up to you.
Good Luck.
Sweetmo wrote:Today (3/21/20), I had an issue with my Orbi RBR40 connecting to internet, so I immediately went to the app and saw a note indicating new firmware was available. After two attempts to leverage the app to update the firmware whic was v2.3.5.32, I went to the computer to access the router instead. I finally was able to get it updated and it's working fine.
When I try to go out and understand the firmware update and review release notes, I can't actually find anything for V2.3.5.32 for the RBR40 . I see a "hot fix" labeled V2.3.5.34 and a prior release V2.3.5.30 , but nothing for what I currently have. Is there something I am missing? Shouldn't I see the release notes for V2.3.5.32?? And why doesn't RBR40 show up as an option for model but RBS40 does??
