Sweetmo
Mar 21, 2020Tutor
Firmware V2.3.5.32
Today (3/21/20), I had an issue with my Orbi RBR40 connecting to internet, so I immediately went to the app and saw a note indicating new firmware was available. After two attempts to leverage the ...
Mar 23, 2020Guru - Experienced User
Is this working for you?
Nest68 wrote:
From orbi webinterface firmware update Page. V. 32 is bug fix. Fixses issues where the armor activation might fail during installation.
Nest68
Mar 23, 2020Aspirant
Havent tried.
- FURRYe38Mar 23, 2020Guru - Experienced User
I see it's no longer available since v34 was posted. :smileyembarrassed:
- Nest68Mar 23, 2020AspirantSomething is strange about this. 32 is the update provided in the firmware menu in router setup. Its not on the page the link you provided leads to, though. 34 has been aviable as a hotfix for a long time and adresse https certificates. Im on 30, and it is stable for me.
You don't have to install the update. If your system is working. Leave it. Be sure to make a back up configuration to file for safe keeping.
Enjoy.
