jto74
Aug 26, 2020Initiate
Firmware V2.5.1.22 seems to be creating problems with Orbi Satellite RBS40
Since my RBS40 updated to V2.5.1.22 the devices connected to it are frequently losing internet connection. The other satellite is still on V2.5.1.16 and works without problems. Does anybody have pr...
kent11
Sep 18, 2020Aspirant
GCassulo wrote:Hi, also my Orbi RBR 40 (connected to RBW30 satellite) has updated to v2.5.1.22 too and since that I have some connections problem.
Obviously the v2.5.1.22 has issue and just try to manually restore the v2.5.1.16 then unplug both devices for awhile. If that still doesn't work, then you may have to reset the devices, although I doubted if the resetting process according to the manual is actually work as I tried the reset and my experience was all the old setting, including device name, SSID and even password, were still there afterward. But at that time the firmware version was the one before v2.5.1.16 so hopefully they have fixed the issue.
GCassulo
Oct 01, 2020Aspirant
Today i have downgraded my RBR40 firmware from V2.5.1.22 to V2.5.1.16.
After reboot in Firmware update section I see that there is a new version V.2.5.1.22 but if I looking for it on Netgear site I can't find it.
Where came from this verision ?
- FURRYe38Oct 01, 2020Guru - Experienced User
IT's on NGs auto update servers however has not been posted to the public download web site as of yet. You don't have to update either.
GCassulo wrote:Today i have downgraded my RBR40 firmware from V2.5.1.22 to V2.5.1.16.
- XalintOct 01, 2020Aspirant
When you check for new firmware in the router interface it was offered. I had updated to it a week a go or so still no issue out of it.
