gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption.    New Version: V2.5.1.8    Release Notes:  [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
rhino-1
Dec 14, 2019Tutor
The first issue I'm experiencing with firmware 2.5.1.8 is the inability to turn on remote management from the app. I can enable it from the web interface but the app does not allow me to enable it so I can access my Orbi remotely from the app. I did a full restore back to factory settings before applying the update.
I receive the following error:
"Some error occured while enabling/disabling remote management"
CrimpOn
Dec 14, 2019Guru - Experienced User
My community forum page has an orange banner across about "an issue with Remote Management fucntionality." (That won't go away when I click on the 'x', but that's another issue.) They say it's fixed, unless it's not fixed.
