gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption. New Version: V2.5.1.8 Release Notes: [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
tomschmidt
Dec 15, 2019Virtuoso
For those that have installed v2.5.1.8 firmware, have you checked to see if the https certificate is updated to be properly signed by a certificate authority? Does opening https://orbilogin.net/ open as a secure web site in your web browser? Can you check the certificate for when it will expire again?
gr8sho
tomschmidt wrote:For those that have installed v2.5.1.8 firmware, have you checked to see if the https certificate is updated to be properly signed by a certificate authority? Does opening https://orbilogin.net/ open as a secure web site in your web browser? Can you check the certificate for when it will expire again?
Chrome complained, so it still appears broken to me.
