gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption. New Version: V2.5.1.8 Release Notes: [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
CrimpOn
Dec 17, 2019Guru
SW_ wrote:
The inclusion of "Fing" might have made the difference. In term of performance,
Fing is a popular software tool for scanning networks and deducing the manufacturer of the ethernet interfaces. It has (literally) nothing to do with speed. Speed improvements have come somewhere else.
SW_
Dec 17, 2019Prodigy
CrimpOn wrote:
SW_ wrote:
The inclusion of "Fing" might have made the difference. In term of performance,Fing is a popular software tool for scanning networks and deducing the manufacturer of the ethernet interfaces. It has (literally) nothing to do with speed. Speed improvements have come somewhere else.
Based on the incremental FW change/description, if performance benefit isn't coming from the inclusion of "Fing", i.e., enhanced devices recognition, where is this "somewhere else" exactly? For references, I don't use DIL, Armor, and Sonos. CPU uage in v2.5.0.40 is extrememly high due to devices scanning and I don't do speed test while trying to rename devices at the same time. Take a look at the picture bellow from a previous post regarding performance degradation/issue with v2.5.0.40.
Based on your above statement/claim, please share with us what you believe to be the "source" for the improved performance in v2.5.1.8. I'm ready to listen and learn about your insight. Thanks!
New Features and Enhancements:
- Enhances the device recognition mechanism of the attached devices list
- Add DAL into firmware for several features, like DIL, Armor.
- Include Fing for device recognition.
Bug Fixes:
- Fixes the compatibility issue with Sonos devices.
- Update the web server certification of RBR50/RBS40
- CrimpOnDec 17, 2019Guru
Didn't mean to offend anyone. I have no idea what Netgear did to improve performance. What I DO know is that one person has looked at Netgear's code and found ways that he claims makes it run faster:
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-v-2-5-0-42sf-hw.60308/
Things like using the Neon instruction set, changing compiler options, etc. are open to Netgear just like they are to him. I am also happy to admit that Netgear's home grown device lookup software may have been so terrible that incorporating Fing software made a dramatic improvement in performance. Maybe Fing is "the answer" all by itself.
- FURRYe38Dec 17, 2019Guru
Curious, are you seeing the same CPU load now with v1.8 loaded? Or is it lower?
SW_ wrote:
- SW_Dec 17, 2019Prodigy
CrimpOn wrote:Didn't mean to offend anyone. I have no idea what Netgear did to improve performance. What I DO know is that one person has looked at Netgear's code and found ways that he claims makes it run faster:
It's possible that NG would suddenly decide to change the compiler options between v2.5.0.40 and v2.5.1.8 due to significant performance improvement. Assuming the compiler options were the "source", I would expect to see that reference/change description in the release notes. For example, let's take a look at the release notes for a prior release v2.3.1.44 as a reference.
v2.3.1.44
Includes bug fixes for stability and performance:
- Fixes the LAN/WAN bidirectional throughput on the DHCP mode drop issue.
- Fixes the downstream drop issue when port forwarding is enabled.
- Fixes the issue where some online games periodicity lag.
- Fixes the issue where the PPPOE connection unstable
To see the performance effect of "Fing" in v2.5.1.8, just check the speed of the "Attached Devices" page between the two releases. The devices are populated much faster and that page is more responsive with v2.5.1.8 than v2.5.0.40.
- FURRYe38Dec 18, 2019Guru
Voxel does his own development on some NG FW. Yes he's just started working on Orbi since he was able to get his own Orbi HW. Users have been asking for his help in the FW realm for a while now. I recommend not confusing what he does with what NG does. Stock FW differs from Voxels FW. Voxels FW is tuned and updated for outside of the NG core code. Items that Voxel has access too and is free to develop as he chooses. There are some items with in the NG code, in fact all NG code that isn't GPL, Voxel has no access or ability to change. Any problems here, NG still needs to address these here.
Read the release notes of what Voxel does. You can see that he mostly updates the FW packages that work with in the FW he has access too. Ensures that what he does works, then posts it out for people to try and use. He always open to bug reports from users to that help him fine tune any issues he may have not seen.So yes, Voxel can help improve FW and most of the time does and has great success. His long time development of the R7800 and R9000 has helped user keep these two routers going for users who have chosen to use his FW over stock. Now that he has a Orbi 50 series system, this will benefit this series system and help users enjoy the Orbi for a more sustained longer life of operation who want to give Voxels FW a try.
Since NG has fixed the device naming issue will be nice to see Voxels version based on v2.5.1.8.
- DaVinceeJan 09, 2020Tutor
I posted my two cents about device renaming before finding this ariticle and the new firmware. Applying it today and see what happens. Thanks for the heads up on the forums: it makes life a bit more predictable :smileyvery-happy:
