gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption.    New Version: V2.5.1.8    Release Notes:  [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
Jan 16, 2020Guru - Experienced User
I would post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Ensure the Orbi app is up to date as well.
rhino-1 wrote:The first issue I'm experiencing with firmware 2.5.1.8 is the inability to turn on remote management from the app. I can enable it from the web interface but the app does not allow me to enable it so I can access my Orbi remotely from the app. I did a full restore back to factory settings before applying the update.
I receive the following error:
"Some error occured while enabling/disabling remote management"
DWHITE4245
Jan 29, 2020Aspirant
2.5.1.8 no longer seems to be available from the Downloads area. I get 'File not found'.
- FURRYe38Jan 29, 2020Guru - Experienced User
Still there and links are working:
https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8
DWHITE4245 wrote:2.5.1.8 no longer seems to be available from the Downloads area. I get 'File not found'.
- DWHITE4245Jan 29, 2020Aspirant
Thanks, I took the route through Support->RBR50->Firmware and Software downloads and that doesn't work.
I'll use your link and see if it installs OK.
Ok.
Your path works for me though. :smileywink:
