gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption. New Version: V2.5.1.8 Release Notes: [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
isareeves
Feb 08, 2020Tutor
Before I updated to V2.5.1.8 I could see all of my 84 attached wi-fi devices. Since the update, I never see more than 4 attached devices. I have rebooted the router and the three satellites 3 times. Nothing changes! HELP! What happened?
Feb 08, 2020Guru - Experienced User
Clear all browser caches, exit the browser then relauch and open the page.
Does a different browser exhibit the same thing?
Try a factory reset on the RBR and setup from scratch.
- isareevesFeb 08, 2020TutorThank you... I tried all of your suggestions. Still no luck. ☹️
