gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption. New Version: V2.5.1.8 Release Notes: [Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] F...
Mar 17, 2020Guru - Experienced User
No issues since v2.5.1.8 loaded on my RBK50. No DNS timeouts, blocked web sites, wifi or internet drops. Device naming is fixed on this version. Though on RBS in a web browser, it shows "unknown" for device names. Most stable version to date.
Factory reset is recommended then setup from scratch. I reset mine after each update and save a new backup configuration to file for safe keeping.
bolingde wrote:Ever since upgrading (automatically) to v2.5.1.8 everything on the network has been dropping connection. I mean everything because it's roku's, PC's (windows), phones (android), xbox connected to the satellite. It' fairly often (maybe every 15 minutes) and lasts for maybe 5-15 seconds. Never had any problems before.
I was going to roll back to v2.3.5.30 but when I go to the manual update page it only gives me the option to "check" one satellite so it worries me to try and roll back.
Two questions.
1. Is anyone else having problems with v2.5.1.8
2. Why would only one satellite be showing up on the manual upgrade page.
bolingde
Mar 17, 2020Guide
Thanks for suggesting factory reset,, but I'll think I'll hold off that mess for awhile.
None of the other really matter because it was all working before v2.5.1.8
