bugmugger187
Oct 28, 2020Aspirant
firmware v2.7.0.70 on rbr50
Just got the new firmware update and now I can only get to websites that end in .com. Is anyone else having this problem?
- Oct 28, 2020
Problem was resolved by internet company after 8 hours.
Oct 28, 2020Guru - Experienced User
I'm on the same version and not currently having issues. i did a factory reset and reinstall afterwards though as I was rebuilding my network (again).
Have you tried this?
bugmugger187
Just noticed the problem this morning and have a call in to internet provider. Just wanted to know if it was a problem with router.
- FURRYe38Oct 28, 2020Guru - Experienced User
- bugmugger187Oct 28, 2020AspirantArris TM3402A. Imon
Has a power OFF of the Orbi system and ISP modem for 1 minute then back ON been performed yet.
Or try a factory reset. Saw some posters having problems on v70.
There is newer FW available as well if your in the US region:
Or
