Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
LeBullet
May 28, 2017Apprentice
Yeah I agree, it's definitely worse than last version, I've downgraded 2 versions, as that was better
- ppilot212May 28, 2017Star
Through support I was able to get the new beta firmware and that seems to have fixed things. I am guessing the next public release isn't far away guessing on the comments their tech support.
- samsamsamsamJun 02, 2017Guide
LeBullet,
How were you able to downgrade the firmware and stop the unit from auto-updating to the latest? My unit was working perfectly before 1.10.1.2. and everytime I manually load the previous version it automatically updates itself in a matter of minutes.
- LeBulletJun 02, 2017Apprentice
It seemed I wasn't, the next day, it had auto updated itself and my issues have returned in earnest.
youd kind of hope they'll add this "check box ", wouldn't you
aG
- CamoitJun 02, 2017Star
I think it's worse then the iPhone. There is no way to stop the upgrades now. Fustrating.
- LongiJun 05, 2017Initiate
Thanks for the hints; how can I get the beta firmware from support?
I'm using an app as baby monitor and the instability of this version is driving me absolutely mad.
- DarrenMJun 05, 2017Sr. NETGEAR Moderator
Hello camoit
No way to stop auto updating.
DarrenM
- dwabramJun 06, 2017Initiate
I have started having the drop issues as well after about 30 days of the Orbi working perfect. All of my devices drop the wifi signal. Sometomes I can turn wifi off and back on at the device and sometimes I have to re-sync the satellite. I am getting very frustrated after spending this amount of money, My wifi signal wasn't as strong throughout the house before, but at least it was consistant.
