Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
LeBullet
May 28, 2017Apprentice
Yeah I agree, it's definitely worse than last version, I've downgraded 2 versions, as that was better
samsamsamsam
Jun 02, 2017Guide
LeBullet,
How were you able to downgrade the firmware and stop the unit from auto-updating to the latest? My unit was working perfectly before 1.10.1.2. and everytime I manually load the previous version it automatically updates itself in a matter of minutes.
- LeBulletJun 02, 2017Apprentice
It seemed I wasn't, the next day, it had auto updated itself and my issues have returned in earnest.
youd kind of hope they'll add this "check box ", wouldn't you
aG
- CamoitJun 02, 2017Star
I think it's worse then the iPhone. There is no way to stop the upgrades now. Fustrating.
- DarrenMJun 05, 2017Sr. NETGEAR Moderator
Hello camoit
No way to stop auto updating.
DarrenM
- dwabramJun 06, 2017Initiate
I have started having the drop issues as well after about 30 days of the Orbi working perfect. All of my devices drop the wifi signal. Sometomes I can turn wifi off and back on at the device and sometimes I have to re-sync the satellite. I am getting very frustrated after spending this amount of money, My wifi signal wasn't as strong throughout the house before, but at least it was consistant.
- OrbiPhilipJun 09, 2017Luminary
Not being able to block firmware updates is a critical design flaw, and an absolute show stopper for any business deployment.
- CamoitJun 09, 2017Star
If you have a half deacent router you can block it from updating. See post above.
