Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
samsamsamsam
Jun 02, 2017Guide
LeBullet,
How were you able to downgrade the firmware and stop the unit from auto-updating to the latest? My unit was working perfectly before 1.10.1.2. and everytime I manually load the previous version it automatically updates itself in a matter of minutes.
LeBullet
Jun 02, 2017Apprentice
It seemed I wasn't, the next day, it had auto updated itself and my issues have returned in earnest.
youd kind of hope they'll add this "check box ", wouldn't you
aG
