Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Jun 06, 2017Hey everyone, these issues are caused by the Orbi backhaul from the router dropping constantly. You can reference this thread for more info. https://community.netgear.com/t5/Orbi/Orbi-backhall-signal-dropping-to-Zero/td-p/1276320
This is a critical failure and Netgear is not addressing it. Please take a chance and look at your Backhaul signals and post your results! There's not a single example of one that does not look like an EKG.
superben79
Jun 07, 2017Apprentice
orbi just restarted itself, nothing shows in the log why. firmware is still the same. this is the 1st time this thing restarted itself for no reason. is this a known issue in 1.10.1.2?
