Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
bestguess
Jun 14, 2017Star
Still having dropouts with apple devices now
LeBullet
Jun 15, 2017Apprentice
So, overnight, we're still getting some Nest connection drops, but my ipad battery drain seems better, I've not used it much to really tell, but it definitely seems like progress.
My Sky Q issues (in terms of terrible and dropped Wifi connections across the system and across the internet) are resovled and it's now performing as it has done this last year.
Overall, it's definitely looking like a good step forwards
Bullet
