Camoit
May 26, 2017Star
Firmware Version 1.10.1.2
Does anybody know what they fixed? All it has in the release notes is "fixed some bugs" That is not a release note. That is a joke.
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Camoit
Jul 06, 2017Star
UPDATE: The IP addres of 216.151.177.114 is not the address that the unit uses to update the firmware through. So blocking did nothing. I guess I need to strat tracing and logging what is going out and in. But that can be a problem since there is so much trafic through the servers.
DarrenM
Jul 11, 2017Sr. NETGEAR Moderator
Hello Everyone
Thanks
DarrenM
