DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
Lydosine
Dec 19, 2019Initiate
Furry - As stated - I did a complete factory reset as stated in my post. Also rebuilt configuration. Using Chrome. And as I stated I also tried the Orbi App (iOS) and cant rename there as well so its not just a browser issue.
I am very much willing to bet I am not the only one with these issues. I suspect as I did with the other 2.5.0.40 this FW will be pulled again. Furry somehow you never have issues. I think you also stated 2.5.0.40 was good. Anyway thanks but this needs NG to fix.
Dec 20, 2019Guru - Experienced User
Next time try a different browser. Others are also having same experience so I'm not the only one either.
Both v38 and v40 also has the problem.
Good Luck.
Lydosine wrote:Furry - As stated - I did a complete factory reset as stated in my post. Also rebuilt configuration. Using Chrome. And as I stated I also tried the Orbi App (iOS) and cant rename there as well so its not just a browser issue.
