DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
RoboPapa
Dec 30, 2019Guide
Since upgrading my RBR50 and RBS50 to firmware v2.5.1.8, I am no longer able to view any connected devices on either router or satellite Using the IOS ORBI app.
Most but not all connected devices are viewable in the Web Interface.
Can anyone advise what I can do to correct this?
peteryung
Dec 30, 2019Tutor
I encountered the same problem. So I manually downgraded the RBR50 router to 2.3.5.34 but the satellite is still with the 2.5.1.8
The devices map comes back, wait for a solutions or next version firmware.
Regards
Regards
- dhoplus2Dec 31, 2019Guide
I'm curious how you were able to manually downgrade the device? From my understanding the issue was that when the firmware upgrade happens, the ethernet port stops communicating so there's no way of logging onto the web interface. Is there another way of doing that?
Dan Hostetler
Regards- peteryungJan 01, 2020Tutor
https://www.netgear.com/support/product/RBK50.aspx
https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
go to the link aboveDownload the right version firmware, you can check thru the hot fix 2.3.5.34 or the firmware section for 2.2
Login the router admin page thru web browser (10.0.0.1 or orbilogin.com)
Tab Advanced > Adminstration > Firmware update > Manual Update, browse the downloaded Firmware file > Upload Wait to complete and done.
Reboot the router.
- abergJan 04, 2020Tutor
Try to downgrade, but I get a internal error 404 when try to do this.
I also don;t see any device which is connect to the orbi.
Seems to be a big bug in this releas and I don't understand why Netgear this bug did not notice
