DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
RoboPapa
Dec 30, 2019Guide
Since upgrading my RBR50 and RBS50 to firmware v2.5.1.8, I am no longer able to view any connected devices on either router or satellite Using the IOS ORBI app.
Most but not all connected devices are viewable in the Web Interface.
Can anyone advise what I can do to correct this?
CC77
Jan 01, 2020NETGEAR Expert
Hi there,
Regarding the connected device list not showing anything within the app, could you please help reproduce the issue, and then shake & submit an instabug log? Please also reply to this thread when its been done.
thanks,
NETGEAR Team
- TehTarikManJan 04, 2020Tutor
I'm also having the same issue - after maunally upgrading to v2.5.1.8 on both the router and satellite unit, the Orbi App on IOS (13.3) is not showing information in the Network Map. The Network Map is still showing the Internet, connected Router (RBR50) and the connected Satellite (RBS50) but when you click on the Router or the Satellite, it comes back with 'No connected Device Found'.
However, in the 'Device Manager', it shows the number devices and when you click on it, it shows the list of device names but NOT their device type. All are listed as unknown. When drilling down onto the individual device, it says ' This computer is not connected to your network' eventhough it is connected and you can ping it.
The Orbi App (v2.4.12.5) was working fine previously with the previous firmware. I've tried deleting the Orbi App and re-install but with the same results. Orbi Router & Satellite have also been rebooted - short of doing a factory reset.
Anyone seeing the same issue?
- peteryungJan 04, 2020TutorYou are not alone. I have the same issue and now rolled back to 2.3.5.34. The latest firmware 2.5.1.8 certainly has issues, at least to the users in this thread.
