DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
rjantigua
Feb 09, 2020Guide
My issue is slightly different. I successfully updated the two RBS50 satellites to 2.5.1.8 successfully, but have been unable to update the router (RBR50) itself. Doing the manual update, I point to the downloaded .img file (from .zip) and hit update. It spins for awhile then comes back with the original version V2.5.0.38. I've also tried the auto update tab, but the update button is disabled. Trying from the Orbi app has the same results. How do I get this thing to update without doing a factory reset. I have recommended the Orbi to friends and now I'm embarrassed. I believe only one or two updates since I purchased the router has worked flawlessly.
Using Android (Samsung 9+) and Windows 10, both with Chrome browsers.
Update, just tried the same update in Microsoft Edge, and the router upgraded successfully. WTH?
Feb 09, 2020Guru - Experienced User
Please remember for future updates, update the RBS first, then the RBR lastly.
Enjoy.
rjantigua wrote:My issue is slightly different. I successfully updated the two RBS50 satellites to 2.5.1.8 successfully, but have been unable to update the router (RBR50) itself. Doing the manual update, I point to the downloaded .img file (from .zip) and hit update. It spins for awhile then comes back with the original version V2.5.0.38. I've also tried the auto update tab, but the update button is disabled. Trying from the Orbi app has the same results. How do I get this thing to update without doing a factory reset. I have recommended the Orbi to friends and now I'm embarrassed. I believe only one or two updates since I purchased the router has worked flawlessly.
