DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
radamchak
Feb 15, 2020Guide
Installed v2.5.1.8 "automatically". Wondered why router and satellites did not sync. I ended up reinstalling manually, to be sure it was done correctly, then "factory reset" router and satellites. Network came up after this workflow. Go figure. Upload speed seems to be about 3-4Mb/sec slower, even after changing Speedtest servers.
Feb 17, 2020Guru - Experienced User
Maybe NG put it up for auto check update now. I also noticed a slight performance dip. Wasn't anything major.
radamchak wrote:Installed v2.5.1.8 "automatically". Wondered why router and satellites did not sync. I ended up reinstalling manually, to be sure it was done correctly, then "factory reset" router and satellites. Network came up after this workflow. Go figure. Upload speed seems to be about 3-4Mb/sec slower, even after changing Speedtest servers.
