DatabaseJase's avatar
DatabaseJase
Luminary
Dec 16, 2019
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here:
https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8
No mention of specific fixes to device labelling and release notes seem identical to the update they pulled.  Also doesn't mention anything about the speed degredation many suffered with that now removed release.
Having been bitten with the last release, causing a rollback to the current "stable" (v2.3.5.30) release, I'm going to take a wait and watch approach to this one.  Interested to read the experience of more adventurous Orbi owners.
  • Can help me sulotion for mr1100 stc blocked 4g in saudi arabia
    • Rob21's avatar
      Rob21
      Netgear company give sulotion for stc blocked mr1100 in saudi arabia
  • I updated from 2.3.5.30 to 2.5.18 yesterday and reset to factory settings after the update.
    I am able to set Device Model and Icon in the web UI, but this doesn't reflect on the iOS app. Setting this will default to Unknown each time I open Devices in the app.
    I thought this issue was fixed in 2.5.18, which was present in the pulled update, 2.5.0.40.
    What should I do now?
    • tomschmidt's avatar
      tomschmidt
      Virtuoso
      From what others have reported, it may take 24 hours or more for the iOS app to see the WiFi devices.  It appears that their DHCP lease needs to be renewed before the iOS app will see them.  Wired network devices reportedly are seen after the firmware update, but WiFi devices can take 24 hours to be seen.  The Android app and the web interface both see all devices immediately after the firmware update.  NG has not fixed the iOS app yet to address this issue.
    • FURRYe38's avatar
      Please post about this in the Orbi app forum:
      https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
      Good Luck.
      • BigRune's avatar
        BigRune
        Apprentice
        I have been running a RBK50v2 system for about a month. The one RBS50 is wired to the RBR50, both on fw 2.3.5.30.
        All running well, great speeds and all. About a week ago the WiFi was unreachable so I rebooted. In the Orbi app I noticed that fw
        2.5.1.8 was available for update. As I did not have any problems I decided to not update.
        Today when I got home the Internet connection was offline, magenta ring showing on router. Wifi working great locally and i rebooted through the app.
        Now I notice that the fw update is no longer available through the Orbi app or through the web online update tab.
        What is going on?
        Is it a coincidence Netgear announcing fw availability messes up my Orbi system?
        Do I really benefit in stability from upgrading my 2.3.5.30 system to 2.5.1.8?
        Do Netgear want me to upgrade my Orbi system or not?
        Displaying devices with wrong images does not bother me. Losing WiFi and/or WAN connection does bother me!
        My previous router was a AC3200 Dlink, rock solid for 5 straight years. Never rebooted even once other than with power outs or moving equipment.
  • Installed v2.5.1.8 "automatically". Wondered why router and satellites did not sync. I ended up reinstalling manually, to be sure it was done correctly, then "factory reset" router and satellites. Network came up after this workflow. Go figure. Upload speed seems to be about 3-4Mb/sec slower, even after changing Speedtest servers.
    • FURRYe38's avatar
      Maybe NG put it up for auto check update now. I also noticed a slight performance dip. Wasn't anything major.
  • I’ve been having a lot of issues with WiFi handoff between router/satellites since this update. Never had any issues before and now most devices don’t hand off when I’m moving around my home—I end up having to disconnect and reconnect to WiFi. Anyone else having this issue?
    • FURRYe38's avatar
      Above suggestions working:
      https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
      Has a factory reset and setup from scratch been performed since last FW update? IF this doesn't resolve anything you can downgrade back to last working FW version.
    • Anonymous's avatar
      Anonymous
      What Orbi/firmware on you on?
    • InvisibleWAN's avatar
      InvisibleWAN
      Everything was good with this firmware until I tried to add an additional device (iPad).
      It connects to main router fine with full access BUT the synced satellite will not allow access (my admin setting was to disallow new devices, but I authorized the iPad).
      Clearly there is an issue with setting updates reaching the satellite. In fact, I have no logs from the satellite reaching the main router.
      Once again Netgear has displayed its ineptitude in maintaining core functionality. Not much different than Apple releasing an iPhone update which breaks the ability to make a call.
      Tired of this.
  • The file downloaded can't be opened, is this a windows only file? Is there a mac version?
    I have tried from Orbi app but its says it has updated but then reboots and has same upgrade option indicating it has not worked
    • FURRYe38's avatar
      .zip files are both Windows and Mac supporting. Both Windows and Mac have built in package file handlers to unpack the .zip file. They may not work if the .zip file was downloaded as corrupt or not fully downloaded correctly.
      First manually download the RBS and RBR FW files from here.
      http://kb.netgear.com/en_US/000061838/ if you want to update to v16
      Unpack the FW from the .zip files.
      Use a wired PC for this process. Safari(Mac), IE11(Windows), Firefox or Opera browsers are recommended.
      Log into the RBSs web page and send the FW file there first.
      Then send the RBR FW file lastly.
      Factory reset the RBS and RBR and setup from scratch. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
      I recommend keeping this method, as it's a proven method I and others have been using for years to update router FW.
      • DerekWatson's avatar
        DerekWatson
        Hi
        I have tried downloading the file again (5 times now) and get this error each time I try to open it. Its is a .img file which is why I queried if it was a windows file in the zip archive?
