DocMusicman
Jul 20, 2021Initiate
Firmware warning for Homekit/V2.7.3.22
I updated to 2.7.3.22 last night on my RBR40 and homekit started having major issues (specifically with hue and arlo). I could access everything when on wifi but not when away. I rolled back the fi...
Jul 20, 2021Guru - Experienced User
Will need to try a factory reset after new FW is applied to see if this changes anything. Possible left overs from configuration may not work well with newer version of FW.
A reset and setup from scratch is needed before pointed to FW.
- DocMusicmanJul 20, 2021Initiate
Thanks. I did rebot everything, but did not completely reset and start from scratch. I will just roll back for now and if I have time to do that later I will.
- FURRYe38Jul 20, 2021Guru - Experienced User
:smileywink:
- catboat_MNDec 23, 2021Aspirant
how do I role back?
