DocMusicman
Jul 20, 2021Initiate
Firmware warning for Homekit/V2.7.3.22
I updated to 2.7.3.22 last night on my RBR40 and homekit started having major issues (specifically with hue and arlo). I could access everything when on wifi but not when away. I rolled back the fi...
catboat_MN
Dec 23, 2021Aspirant
i did that and all the downloads are corrupt
Dec 23, 2021Guru - Experienced User
Try a different wired PC and web browser. IE11, MS Edge or Firefox.
- JakeRichJan 07, 2022Aspirant
Did this get fixed? I have the same firmware with one RBR50 and three RBS50 satellites and all of my Homekit devices are randomly dropping out. Most are from Meross, some are iHome. I'm trying to convert from Insteon to Homekit, but nothing is stable. I tried turnign down the 5Ghz power to 25% to force iPhone to connect at 2.4, but no change. I also set Beamrormng and Enable Mu-MIMO, no change. I can see all of the devices connected to the router in the "Attached Devices" view, so I know they are connected. But neither the Home app on my iPhone 13 (iOS 15.2), nor the Meross app can see all of the devices. Distance doesn't seem to be part of the problem as I have brought 4 of the "missing" devices into the same room with the router, about 6 feet from the RBR50, and I'm also in the room with the router and the devices appear/disappear/no Response randomly. My home is large, a bit over 4000 sq ft, and needs the three satellites for consistent coverage on all three floors. Sure would like to get this working soon. Any help is appreciated.
I missed the errors. It should read, "I also set beam formiing, "
