Evert22
Aug 13, 2020Aspirant
First no internet connection on my orbi RBR40, now it wont factory reset or setup a new network.
Hello, I have a problem. Today my orbi network stopped working out of nowhere. The router ring led is flashing white. It consists of a RBR40 and a RBW30. It has worked perfecty for the last 6 mo...
Evert22
Hi, thanks for your repley.
When i press the restart button for 15 seconds nothing happens.
Also, when connecting a wire nothing comes in.
I have asolutely no idea what could be wrong.
Aug 13, 2020Guru - Experienced User
Possible the RBR is faulty. I would make contact with NG support to see what your options are.
