Evert22
Aug 13, 2020Aspirant
First no internet connection on my orbi RBR40, now it wont factory reset or setup a new network.
Hello, I have a problem. Today my orbi network stopped working out of nowhere. The router ring led is flashing white. It consists of a RBR40 and a RBW30. It has worked perfecty for the last 6 mo...
Evert22
Aug 15, 2020Aspirant
Thank you so much all for your tips.
Unfortunally none of them worked.
The power led did turn to red, but after that it turned to green again and the ring led keeps on blinking white. So i also still cant create a new network.
Mstrbig
Aug 15, 2020Master
That is exactly what was supposed to happen, meaning your satellite is fully reset and ready to pair. Now you fire up the app and add a satellite. If you cannot add a satellite, then I suggest you factory reset the Orbi router and start again.
Not to be rude, but setting up these systems is a very easy task, if all instructions are followed. When someone absolutely cannot figure out how to achieve this, the best thing to do is hire someone that knows how to install a wireless mesh system on an existing network.
The only problems I ever see is if the system was used or a return, and not reset when sold, or the system is defective. Because of the possible used / return factor, I reset every system, including wrapped out of the box.
